Mike Licht
I was here first
- May 23, 2001
get the part number off the injector too "green strips" can be anything from 24 up
SignUp Now!Mike Licht said:get the part number off the injector too "green strips" can be anything from 24 up
Injector part nos as follow
621031
D3181AA
What are these ?
3.8L V-8 eater said:Keep us posted on this. When I get my car out of storage I have to chase the same problem.. G.L. and hopefully it doesn't turn out to be a big issue....
bb's turbo t said:Also had that same issue. Mine was loose bolts at down pipe and turbo.
TurboBuRick said:Are you sure it's a pop and not just misfiring?
Did you try unplugging cam sensor?
Did you check rocker movement?
If the problems are just at wot it's not the ecm.
Most of these guys are just throwing things out there to be checked. If you want to find the problem listen to what I'm telling you and follow through with diagnostics.
1badbuford said:Will do
Waiting for double pumper to come in next week from Canada
Eh
