Car pops @ WOT.
Fuel pressure is fine. I've swapped everything spark related with known good parts.
Nothing obviously hitting (positive cable on downpipe, or anything like that).
Twice the car has lost power to the ECM (Direct Scan readings all go to zero for 2-4 frames). Once after it lost power, it threw a code 42. The other time, nothing.
Direct Scan shows voltage at 12.8-13.3 when at idle and ~13.8 @ WOT (seems kind of low, car has a Red's volt booster).
Once it threw five codes as soon as I started it (24, 25, 32, 34, 42).
Sound like a bad ground? Bad hot wire to the ignition module?
Need to get this taken care of as I'm trying to sell the car, but don't want to sell it not running like it should. Thanks in advance.
