Ported inlet Bell...how to bolt on??
Tmhyer
I just bought the ported aluminum inlet Bell for the stock turbo from PTE.
How do you bolt this on? There is no room for the nuts to thread onto the studs now
hold it at end of threads and start the nuts ,,then work them down a little at a time
if that doesnt work head for hardware store and get plain m8x 1.25 hex nuts instead of the flanged nuts
No nut will fit on the stud. The bell is right up against the holes. Someone else has to have had this same issue
Socket head cap screw maybe?
Can I remove the studs that are there and use screws instead? The ported billet inlet bell gives no clearance to be able to use any style of nut
Double nut the studs, and take them out...…..
Thanks for the idea. I think this is exactly what is needed to be able to bolt it on.
