fullahotair
- Feb 26, 2002
1. Ported lower intake and upper plenum (not ported) - ported to match the blue felpro stock replacement gasket. The EGR tower has been gound down and welded. There is small hole drilled in the front of the intake, that is plugged with a brass fitting. Don't know why it was there, but it poses no issue. It taps into the water passage. $250
2. 1 std/std turbo crank - $200
3. 1 .010/.010 turbocrank that will likely need turn down again or a good polish - $75
4. Billet Valve cover breather (pair) - $40
5. Stock ECM, you'll need the both chips for the GN, this is the 1227148 ECM which the GN uses, but out of another car, so you'll need the GN calibration chip. - $30
6. Black painted valve covers - $30
7. Stock heads - $50 for the pair
8. 009 42.5 lb injectors. Bought these news, maybe 5K miles on them. No surpises, just moving up. $120
9. 109 block - std bore $300. I might be able to get it delivered to BPG, but no promises...otherwise pickup is preferred.
10. 2 harmonic balancer's - $40
All parts are plus shipping... Pics can be found here. If you need any more or have a question let me know....
2011-07-18 19:11 pictures from random pictures photos on webshots
Nate
Nate
Nate
Nate
