Dusty Bradford
- May 24, 2001
These heads are identical to the ones I went mid ten's consistently with. They are being sold because the car they were on is being parted out. Porting was done by Hunt Brothers in TN.
Combustion chambers have been smoothed. They have Ferrea 1.77/1.50 valves. Springs are set up for a flat tappet cam and are Speed Pro 110# at 1.70 height. They sealed up perfectly with RJC's headgasket kit and ran 7.50's 1/8 mile on very easy passes with true radials.
The only thing I recommend is installing new valve seals if you prefer to run them. Some of the seals have come loose from the guide which is common on these heads.
I'll have pics tomorrow.
$750 shipped to your door in the 48 states
