Posi now pegleg!
rev. 3:11
"BEHOLD! I COME QUICKLY..."
My posi rear end is now peg leg! I am clueless regarding differentials, had the fluid changed a while back & been driving it very little; buddy pointed it out today that I was only leaving one patch (passenger side wheel):mad:
NOT GOOD
Is car safe to drive am I doing more damage driving, WTF!?!:(
Did a search w/o success
Any help/advice is much appreciated
TIA
D :)
Pop the cover off first and make sure that they're not holding. Put it in gear and try to move one wheel and see what the other does. If it's stock then you can rebuild the carrier.
If its stock good luck finding new clutches. Not impossible but not easy. We did my buddies last year and lucky a new set of clutch packs went for sale on the board. We couldn't find the right clutch packs anywhere else.
Fluid changed recently huh? I put the lube in when I changed the fluid last and got the same result. Drained it and replaced the fluid with no lube and it fixed the problem. Find out if it has some crappy lube in it
Will check all the above this weekend (hopefully)...
Thanks , Gents!
