Hmm.......im confusing the hell out of ya huh? dammit... im at a loss for words, I know some body else knows what I mean.... right?
or am i alone in the left field?
Before we look at rear gear ratio effects, lets boil down a few details.
Are your secondarys opening?
is your air filter dirty?
what is Intial Timing?
What is total timing?
Color of spark plugs?
all of this can provide clues to the possible lack of boost.
Moving on now,
Hmmm how can I put this in perspective........
imagine a manual trans.... a good ol 3 speed....
now start the car and put it in first.... take off..... the car leaves with out much hesitation and is rolling.... but it will only go as fast as you can rev the engine.
This would be a similar effect for the 3.42s
now on the same car and trans, place it in third..... take off....... the car is a pain to get rolling, takes clutch work and you can hear the engine bogg trying to move the weight...... but now you can go much much faster once rolling.
this would be the simular effect of the 3.08s.
it takes little effort to move the car in first, while in third it requires more energy.... this is how the loads can be view in respects to a 3.42 vs a 3.08.
but yes, the 3.42 is going to feel great - will be fast too!
try something,
put it in gear and hold the brakes as hard as you can, rev the engine as high as you can go without the car sliding, spinning tire or pushing to much....... whats your boost now?
A.j.
