jasjamz
THS Racer
- Sep 30, 2004
Car was running fine Friday evening. On the way home I was caught in a thunderstorm I my T-Top GN. Made it home just fine. Next morning I install a FMIC and drive the car to fill up on fuel. Still driving great. On the ride home I get a few stumbles on the highway. No biggie, kept rolling.
I get a mile from home and go to pull off from the stop light and the car is stumbling very bad to the point of wanting to stall with light throttle. Heavy throttle, it stumbles past the low RPM and rips down the street! I get it home park it and run in for my laptop. I notice my map sensor is no longer reading. Says -29 and will not read or graph boost. I figure I have killed the MAP sensor and limp into the garage.
Now things get worse Data screen is flickering, my BLM map is all 128 and the car wil start and idle but any throttle it reads lean of the chart and stall. I have tried an new 3 bar, two ECM's and a coil and module. Still nothing. Car has plenty of grounds.
I did notice I can faintly hear the key in ignition chime which never worked before.
Here is a log with KOEO
Biggest grudge event of the year Saturday and l really wanted to go to the track and test today. Now Im stuck.
Any Ideas? Eric Bob?
