marleyskater420
still needs to learn
- Aug 14, 2004
Is it possible to modify the stock sender so that you can use an external pump with it?
I'd like to use the stock sender and put a -10 fitting on it and run -10 to an external pump, then -8 to my fuel rails.
Is it possible to do that using the stock sender? Could I just run a longer pickup tube (either with some teflon hose or whatever works) and have it rest at the bottom of the tank?
I know there are aftermarket sender units, but they're 200$, and if I can make my own and save some money, I'd like to.
Thank you for your help.
