Possible to tap into the 5v source from the FAST to power extra sensors?
TwinTurboIroc
i am running a cheap 4 channel EXTERNAL datalogger besides the FAST one and i need a 5v source for them.
I know that the MAP, H20, and IAT all have 5v sources going to them and then going to a wire splice in the harness
you think it would be safe to tap 2 more wires into that splice to get my source?
The MAP and TPS have a 5 volt connection but the ATS and CTS do not.
Exactly what would you use the 5 volt signal for? You may be able to do this.
i need to datalog an extra IAT and an extra MAP sensor.....
i can artificially create my own 5v source but i figured this would just be easier
the reason why i need a 5v source for the IAT sensor is that my datalogger doesn't datalog thermistors. So, i know, you are asking yourself if it can't datalog thermistors why are you bothering using an IAT and messing with the 5v source?
well, thanks to my friends on the DIY_EFI email list they explained to me that i can install a bias resistor inline with the signal wire to the IAT. Then supply a 5v source to the sensor and then DATALOG that 5v source as it changes with the resistor
Then all i have to do is do a couple tests with a IAT sensor, thermometer, and some hot water.
Lastly, configure the software (Xv = X*) and then wala, i can datalog my IAT readings :)
I was also told that the IAT sensor's thermistor isn't a linear curve but linear at first and then curves at the end. I am not worried about this, it will be close enough for my purpose
Craig, since only the TPS and the MAP receive the 5v source...you think it would be ok to tap into that 5v supply for 2 more sensors? I mean i dont think the load could be that great
thanks for your help
edit: As you already know, The IAT has its own signal coming from the ECM. I just looked at my modified pin_out list (i installed a single 48pin bulkhead connector to clean up wiring and had to make one) and looked and confirmed what you told me.
here is a nice link to the specs on the GM IAT sensor:
http://forum.aempower.com/bbs/download.php?id=312
Nice tech specs for the IAT! Any chance you have a link to one for the GM 2 bar map sensor???
BTW, i'd be carefull hanging anything extra off of the Sensor +5V...that stuff all seems to be VERY sensative to extra load and voltage draw on it...
How's about just putting a simple +5v regulator where you need the power, and run a standard +12v wire to the reg??? It'd be cheap and simple...
Thanks!
Justin
Thanks!
Justin
check out www.aempower.com and go to the forums.....maybe they'll have the GM 2 bar there
I know i could just get a 5v regulator....no bigge. Just extra stuff i just wanted to make it a little cleaner ya know
