Jul 27, 2009 #1 J jmendlik Active Member Joined Oct 1, 2001 Messages 779 I have Powerlogger and the new FJO wideband. using the .5/4.5 setting per Bob's instructions I have to use "heavy " smoothing setting on the set up chart for the readings to be clear on the graph page. any ideas why?
Jul 27, 2009 #2 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,665 where is the FJO grounded? Post a log Bob
Jul 28, 2009 #3 J jmendlik Active Member Joined Oct 1, 2001 Messages 779 FJO ground Looks to be grouded near ECM on the dash body
Jul 28, 2009 #4 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,665 ground it to the engine, body grounds suck
Jul 28, 2009 #5 J jmendlik Active Member Joined Oct 1, 2001 Messages 779 Fjo Will try a different ground.....Will this heavy setting effect the numbers where I need to worry about the accuracy of the A/F?
Jul 29, 2009 #6 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,665 no it shouldn't
