You are on the right track. See if the pump starts when you turn the key ON. If it doesn't, check the fuse. Fuse is blown...replace with the proper size...30amp I think. Do this with the IGN OFF. Then turn IGN ON and listen for the pump to run. If the fuse goes again the pump motor is shot. If the fuse is good, and the pump still does not run...the switch on the top of the unit might be the culprit. Do these checks before you commit to pulling the whole unit as it might not be neccessary. If the pump runs, but does not shut off in 20 seconds, (make SURE it does NOT run any longer than 20 sec!!! TIME IT!!) Then I would look at getting a new ACC ball. Again, the Acc ball replacement DOES NOT require removal of the whole unit either. If you have further ?'s PM me and I will give you my phone # so you can give me a shout...I suck at typing!!
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
---Keith
