Power plate install question
djj624
Just purchased a used power plate do I use stock replacement plenum and throttle body gaskets?
Sent from my Nexus 6
I'm new to Turbo Buicks and feel I have seen different power plate designs. Is one better than another for overall street performance?
It would be a good idea to replace the two most rear bolts with studs & nuts. After the power plate and two gaskets are installed, there's not much thread left in those two areas and easy to strip them.
Old post, but does anyone know the correct size studs to throw in there?
Take your removed bolt to Home Depot & match up your thread size . I purchased a piece of threaded rod & cut to your desired length ( think I made them about 1/4” longer than the removed bolts.)
Don’t over torque when you install
Use studs or longer bolts in all locations, the factory plenum bolts tend to strip out even without the plate.
TIMINATOR
Do it right ,Use ARP # 661-1003. These are black oxide but you can get them in stainless 6 and 12 point.
