Intercooler
- May 24, 2001
Refresh my memory here...... what was the question?
Originally posted by Two Lane
Maybe some of these night-crawling rodents prospering from the labors of others will have a Sales Booth at BG/Bristol/Norwalk/ET.
Then, we can show our appreciation in person for their valuable contribution.
_________________________________________________
(Thanks, TRK...so that means there was no new news in the prior 4-pgs.)
Originally posted by BoostedBug
I have a NEW RJC plate..am I going to put it on my car? NO! Why? I am going to make one out of 3/8" billit aluminum to serve as a spacer for my upper and I don't want 2 seperate plates on my Intake.
Originally posted by d0n_3d
here are my thoughts on the powerplate...
i installed my PP when my car was pretty much stock...used to run 15 lbs MAXIMUM on 93 octane gas...anymore boost and i would knock...i installed the powerplate and i got up to 16 lbs even 17 lbs of boost without one single degree of knock...i would even sometimes squeeze in 18 lbs in cooler weather...
this was with my stock turbo btw...i switched to the te-44 turbo and 50's on the same stock motor and i can run up to 15 lbs of boost without knocking but that is due to the fact that the te-44 flows alot more air...
i even raced my car at the track with the powerplate...ran a solid 12.2 @ 112 mph with all stock components INCLUDING injectors...i had great top end and great spoolup...
on the street my car idled much smoother and it even accelerated more smoothly...i changed my plugs afterwards and number 5 and 6 were not lean at all...all plugs looked exactly the same...
i have run up to 23 lbs on the stock turbo with 110 octane gas and no knock...i don't think that would have been possible without the powerplate...that's how i ran my 12.2
Originally posted by WakkoSS
I got one of these plates in a trade with someone...how can I be sure it's a "real" RJC plate? It's aluminum, not steel. Appears to be very well made, so hopefully it's a real one.
Does a hole need to be drilled for the EGR?
Originally posted by RareT
I am one of the folks who attended Bowling Green last year and "felt" the difference in air distribution between power plate on/power plate off. That demonstration alone sold me on the product whether it made me go faster or slower.
Ed
Originally posted by Hyper
wasn't that the thing with the leaf blower hooked to a intake? If so that is old smoke and mirrors, see you will feel more air in the rear of the intake hooked to a leaf blower because the is no heads there to creat BOOST!!!, the air is just flowing and it will blow harder in the rear like that. You say the plate made it feel the same on all 6, because it made a restriction!!!well I think they are the same on all six when it is under boost. 20 psi of air filling the rear cylinders is the same 20psi filling the front!!
