Powerlogger and alky-Razor
Quiky One
To input boost on the powerlogger, you have to tap off of the MAP green wire just like you do for the PAC alky. Since I have already tapped off it and ran it into the interor, can I just tap off that again? Will that screw with the signal? Or should I tap of of the MAP in the engine again and run a seperate wire to the logger? I dont want to risk the alky not getting full signal just for boost sensing. Running another wire wont be the end of the world.
Thanks Jason
You can tap into inside the car. Wire is wire. the signal will be the same.
HTH
HTH
Ok thanks. I just didnt want the signal to be "weak". I was afraid that tapping into the wire that is tapped off the orginal wire might be bad.
Thanks guys
