PowerLogger CS Adjustment
dennisL
In the PowerLogger "Adjust Analog Input Properties" window there are 3 boxes for 2nd, 3rd, and 4th gear CS Factor. Its my understanding that these are for converter slippage but I'm not sure how to use them. What is affected after values are entered and how do I determine the values?
The parameters are rpm/mph, the only one I remember is 3rd which is about 47. Once you put numbers there, PL will calculate converter slip and show it on the graph page. adjust it for zero when cruising with the converter locked.
I don't know how close my numbers will get you but you're welcome to try them out. I have a 7 disc vigilante so when it's locked it's LOCKED! and a manual switch so I can lock it in any gear and test the numbers I enter. I just kept massaging the numbers until I saw a "0" CS while cruising along in 2nd, 3rd or 4th.
2nd ---- 75.5
3rd ---- 46.5
4th ---- 31.0
HTH!
Hey, thanks Bob and thanks Dave. I'll try it as soon as the snow melts here in New Jersey.:(
Dennis
