SignUp Now!Wideband AEM Inline UEGO Controllerwhat wideband?
you should only connect the one signal wire.
where is the wideband unit itself grounded?
Bob
, it's for use without the gauge if you have a power logger
It says don't connect the grey wire
White wire - wb signal , which u connect to io connection for power logger
Brown wire - which it says put eyelet on end and attach to screw on ecm
My question for the brown wire is can it be grounded off on any good ground source or can it even be attached to the ground source on the I/o connector for power logger?
So on the I/0 connectors do I. Need to hook up egt and map signal?
You can hook up the MAP to log boost. Get a 3 BAR MAP so you can log accurate boost. I think the stock 2 Bar only logs to 10 or 15 psi.
Why do you want to run an EGT? It depends on your sensor and if it has Volt Signal wire. It should be a Power wire, ground wire and a signal wire that can read anywhere from 0 to 5 volts then adjust INI file.
K gotchaThe powerlogger is a recording/monitoring tool. The map, EGT, etc are optional inputs if you desire to log or record them. They aren't required for the powerlogger to work. As far as your boost gauge....keep it so you can have a heads up display of boost....the map signal simply sends the boost reading to the powerlogger so it can be recorded. EGT is not required either...but if you have the EGT system, you can input it to the powerlogger if you want
I thought you had to hook egt up. I'm following the power logger install instructions
I have a boost gauge also
