Powerlogger not displaying boost currently...
Fitman5150
got a new laptop (Windows 8) for xmas top use solely for my GN. (IM A MAC GUY BY CHOICE)
hooked it up to car last night with PL.
at just an idle, all readings work but boost. only displays -29.5
i was using a slow ass laptop with windows 8 as well before.
any help would be greatly appreciated!
THANKS IN ADVANCE
your MAP sensor signal is not getting to the PL.
Did this work before? Perhaps the beige cable has come unplugged.
Bob
Bob,
yes sir it worked fine before.
beige cable being the one that is plugged in to analog bar behind glove box?
thanks for your response!
Is the reading off? If so there are offsets you can change to get the correct readings. Grounds are the major reason for offset changes . Double check your grounds then play around with the offset .
The reading he's getting indicates there's no signal input from the MAP
Fixed.
PL board in ECM was slightly loose. Secured it with industrial duct tape.
Thanks for every ones assistance!
