- Nov 4, 2005
1)installing 3 bar map for boost monitoring....diagram shows differently than instructions? i put sensor wire like instructions, not diagram....
also,pin out right? i used a tps plug and polarity is backwards from the tps...
2)would like to monitor second fuel pump turn on...12v ok into aux input of pl?
3)can i tie into fuel pressure sensor (dakota digital) to monitor it as well through the other aux input? thanks.
