Powerlogger & TT chip adjustments
Topjimmy
Is it possible to change the Turbotweak settings using only Powerlogger or is a scantool required?
I see the Block Learn Values on the Data screen for INT and BLM but will it cycle in key/on-engine/off mode to show the chip adjustments and integrator settings as well?
TIA - Jimmy
TIA - Jimmy
I think I understand what you are asking. The powerlogger is a scantool that also logs data. Just follow the instructions that came with the chip.
My powerlogger cuts off when I turn the key off. I do the key on and 3 pedals and then reconnect the powerlogger. At that point I choose which value to change in the chip. Hope that helps.
Thanks joe, that should do the trick. I'll pass this on, it's for someone who has PL but no scantool. - Jimmy
