Hey guys did a few checks this evening. I did not get to remove the wheels and look at wheel cylinders themselves but I do not see any leaks at any wheel or under the vehicle. The first problem I had a few weeks ago was i was coming to a stop and the pedal sunk from under my foot brake lt came on once, released and light went out same thing at next light but i was driving slower. Felt like typical MC going bad. As for today
1. Depressurized and took about 12 pumps to do so
2. Key on Pump cycled 15 sec then off Switch clicked correctly
3. Both port test. A and B the fluid stayed at about 1/8 higher than the actual level. Never rose from that and I think I held it there pretty long
4. Step on pedal twice , pump turns on 5 sec then off No brake lt. pedal slowly drops under steady pressure
5. Test again 2 pumps Pump cycles 5 sec then off No brake lt. Apply pressure for 2 min Pump never cycles but slowly sinking pedal
I really feel this is only a MC issue. I am going to try and get it off soon so I can send it to RCG for rebuild Does it sound like that to you guys just double checking myself. And sorry for so long. Thanks VINNY
