Precision SLIC FIT???
Cut an inch off you up pipe at the IC. Not to hard to fix, I've installed 3 now and none rub after doing that. It took me all of 10 seconds to mod the pipes. You're over thinking this man.
10 seconds???? WOW, you need to come to work for me.:) I can't even FIND my bead roller in the shop in 10 seconds.:mad: But then I'm old and can't remember what I had for breakfast a half hour ago.:D
take pipe, cut with band saw, sawsall, cutting wheel. The one that comes with the IC is alum, i8f you can't cut through that in 10 seconds, you've got bigger problems LO, I figured this out and I use to ride a short bus to school! :)
Question for those that have installed these PTE SLIC. I have a used one and the only parts I did not get are the long water pump bolt & spacer, and the stud coupler for lower hole on the aluminum mounting bracket to the block. I know they are M8-1.25 thread. Can anyone give me the lengths so I can source them please?
Thanks,
You can buy them seperate from precision ,and I believe they were reasonable.
Kevin
