Precision T64E Big Shaft Turbo
rdynek
Pulled a T64E Precision off of my car.
Has approx 6k miles on it. Going up to 80mm COMP TURBO
Info found online:
Comes with T04E Compressor Cover - 3" Inlet and 2" Outlet, 66mm 52 trim comp wheel, 76 P trim turbine wheel, .69 A/R On Center T4 housing. These turbo's require an external wastegate. Supports up to 700 hp at the flywheel
$500
Here is a pic of the turbo for sale
What stall converter is needed? Have you been to the track with this turbo? Can i see some wheel pictures, also how is endplay? I may be interest.
Thanks, Dan
Sorry no track time and just to clarify this came off of my mustang cobra so all of my car info would not help you. I only chose to add here because the gn crowd is versed in this turbo and its abilities to perform.
