Precision Vigilante 5-disc converter
johnplogii
Senior citizen
This converter is still in the box from precision. Just had freshened up and new clutches installed. Comes with the pump tube kit & restrictor valve. It was a 6-pump which I thought was a little loose but didn't want a 0-pump so Jack had them change the angle of the fins to make it tighter. Never run. $800 Would consider Weld Alumastars in trade.
Stall
What was the stall at before and Did they say what it would be now?
Chris
Stall
The converter is a "6" pump which is rated 3600-3800 rpm. Actual stall depends on power level and whether you use a footbrake or transbrake. It should be 100-200 rpm tighter now.
L/U or Non L/U?
One other thing is it 3/5/ or 6 clutches? Did they also update so you don't have the rattle in nutral?
Chris
It is now a 5 disc. I have never heard the rattle but I just run a downpipe, no exhaust. If I remember correctly I thought the 7 disc was the one that rattled bad & that's why they quit making it.
As I wrote in an earlier reply I have never heard the rattle but I do not run exhaust so my car is rather loud. I am selling it because I have switched to an art carr unit.
Pictures
I will take some later tonight & have to figure out how to download & send them. The drill bits & pump tube kit are new, never used or installed.
Great seller!
Got the converter today. Looks brand new Just like you said it would be.
Thanks for the deal John. :biggrin:
Chris
