Pressure Guage
CGASTON
Can some one tell me what digital gauge and pressure switch that they are using to monitor the transmission pressure? It would be awesome to have a transducer similar to the fuel pressure transducer that you can monitor with the scanmaster. Please let me know where I can get one or what model your using....
The link in the Post above is only for testing Trans Pr.
That's not what He's looking for.
I don't know if there's a Digital Oil Pr. gauge available with 0-300 & data link.
Check out the Elite series gauges from autometer, they have logging output , don't know if it will work for you or not.
Bryan
Boost231 said:
if you have a XFI or powerlogger it should be pretty easy to do. just get the fittings and wire it up. not a bad idea and now that you brought it up i might do that myself. i use this for right now
http://www.summitracing.com/parts/OTC-5610/
Does your transducer read a different pressure that your gauge. Example, I have FP Transducer (loggin via PL) and it reads almost 10 psi more that my gauge does......
mine are always spot on. you need to calibrate the sensor
im using a xfi and it has me set values. the powerlogger should be able to be tweaked to match as well
