haywire4130
- Sep 11, 2010
i was looking over the crank and bearings on my recently disassembled motor and was quite alarmed when i saw the thrust bearing. the rear was worn so deep that the grooves were completely gone (it now measures 1.027 wide, yikes!!!) and the rear thrust surface of the crank where the bearing rides is nicely counterbored into the journal about .090 deep. my question is: since i don't have a new crank or good pictures to compare it to, is the "counterbore" normal or did it really wear that deep? when i place a new bearing on it, it has about an eight inch of slack fore and aft. i'm assuming this is the only part that regulates front to rear movement. i'm also assuming there is an issue with the converter or something that was forcing the crank forward? if that ends up being true, i wonder what kind of shape the trans pump is in...? i cant believe someone put it together like this! luckily i bought the car right but it's frustrating to do all the detective work and put out all the fires!
