TURBOELKY
 - Jun 27, 2005
3 pages ...
pull the large bypass plug on the oil adapter (1" wrench) and see what spring is in there ,
the NA carbed cars only used a 40# spring
check color of spring and count coils to determine what you have , if its an orange 40# pop in a yellow 60# spring (cheap melling oilpump rebuild kit has all the springs)
heres the spring chart.
if you have a 60# yellow and can only get 38# then you have problems , might need to check that the pump gasket is correctly installed
This is why members like Pacecarta are so important to this forum. He kept it simple and efficient while we all re engineered your situation
