Pro stick installation!! How did u do it.
tbone87
I installed the pro stick but did yall use the factory linkage or what. Or did u wire the neutral safety switch in that came with it. U can also add a backup light switch on the shifter also. If so how did u wire the backup light switch. I used the hatchet looking linkage with the 3 holes like it said but cant use the factory.. Help appreciated much!!!!
I did as most do...cut the factory bracket and weld to the other
Bryan
I did that but wiring (reverse lights) n/s switch!!
If you did the mod shown above AND put the factory linkage back in place then all the issues take care of themselves because you'll be using the original switch for safety and reverse lights. You'll also have the interlock when the key is removed.
May just need to adjust the linkage as it should work as normal when right
Bryan
U cant use the stock linkage with there cable. Not that I seen. I cant see the pic for some reason.
Yes you can. Here's mine hooked up. As you can see, I welded my two pieces together like phoneguy did, but I only used one tiny tack (hard to see).
Since you can't see the pics, basically what you do is align the aftermarket lever with the stock one using the rectangular shift shaft hole as the reference. Then, tack them together. Of course, you may have to do a bit of trimming to the stock lever.
Thanks nothing is easy!! I will figure it out and go that rout.
Cant see the pics!!
Unable to see the pix?? Try looking on a computer. Your mobile device is having issues. I see them on both my mobile devices (Android and Ipad).
Ya I like
I used stock linkage too. Just wallered the hole out a tad.
currently cutting it the F loose
Too bad B&M no longer produces the "Street Stick". I sure like mine!!
I used a old column shift brkt with no weld
