Hmmm, this is starting to bother me. Looking at http://www.gnttype.org/maint/malf.html shows me how easy it is to check engine codes, just using the SES light. After some spring cleaning, I had my car running 15 psi of boost, no problem. No lag, no spikes, it worked great. The other day the SES light was on and I was only boosting to 11 psi (jumping up a little between shifts). So I shut down, turned the key back to "on", and jumped the cable. The light just stayed on. Tried again and waited a while before jumping. Still nothing. Has anybody had this problem and fixed it? Should I just manually clear the codes and see if that "fixes" it? Thanks!
BTW I am getting Turbolink SOON, so hopefully this won't be a problem for very long.
