Problem installing front frame brace...
Rafs-T-Type
Not so Senior Member
I have the SC&C style one and the driver side frame hole is about 1/2" off. Anyone run into an issue like this? You think I should "slot" out the hole?
Yep I would just redrill the hole, there are so many variances n the factory stuff it is tough to make everything fit 100% 100% of the time. no harm in redrilling a hole
Make sure all the bolts are as loose as possible, and try to get that last bolt in. Tighten them with the car on the ground.
I don't think there is any way I can get to them with the car on the ground. I tried leaving the bolts as loose as possible, but it just wasn't going to happen.
