What chip or electronics are u running to run 27.5 psi of boost i only have 15 psi and i have knock???
Red's 106 chip and a Red's XP pump. You might want to look at your pump, injectors and the fuel.. Or it could be very well be false knock at that low of boost depending what your O2 volts are.
Great 60'! I have the same shocks, same sway bar and 275/55/16 M&H DRs and regardless of trans brake or foot brake I can't get below a 1.71
Thanks Eric, I was pretty happy with everything for it being set pretty base line. The car does not vary much between foot or t-brake if the track is up to speed prep wise.
