- Jun 6, 2001
Installed my new 9.5" PTC NL converter this weekend, everything was fine with my Vigilante lock-up. I ran the car for about half an hour with the PTC and all was well. Went to go to work this morning and there was a huge puddle under the car, it was not leaking while it was running that I could to tell yesterday, only when it sat overnight. The tranny is a TCI with a BRF valvebody and was fine before the install. It looked like it was dripping out of the front of the Hughes pan, but I doubt the new gasket is bad, so I removed the inspection cover and am going to install a new new pan gasket, fill it and try again as I just cannot tell if its comming from the front seal area. Wouldn't a bad front seal/bushing leak/cracked converter snout leak while the car is running?
The converter holes (2 out of 3) not lining up perfect with the JW flywheel pissed me off to start with, if this thing is the cause of this terrible leak I'll put my Vigilate back in, what a waste of time. Any advise appreciated.
Mike
Mike
