Please reply only if you have experience with this cam. Thanks.
What type of thrust button are you using? I saw this part number 269 on comp cams website.. looks like it will work.
I bought a used cam that had some Moroso setup that might require machining of the front cover. If you've used this comp piece.. how does it work? and have you had any troubles at all?
Last, what type of end play should I shoot for? I'm new to this hydraulic roller install.
Thanks,
John
Thanks,
John
