PTE Custom WG
Hartline Perf.
Check out Precision Turbos NEW Custom Wastegate!! At a GREAT PRICE!! 46mm wastegate.jpg
PTE's INFO on their wastegate:
These units feature a 46mm
valve, and can be used in a wide variety of applications. They can be
used in any kit or setup that currently utilizes a v-band style 44mm
gate, but will work best with the supplied inlet flange (the inside
diameter of our flange is slightly larger than our competitors). The
wastegates will be shipped with all the necessary hardware (flanges,
clamps, springs, etc), and can accommodate a wide range of boost
pressures (anywhere from 1.5PSI up to 25.5PSI). All units feature a
black, anodized wastegate cap, and a Kevlar reinforced silicone
diaphragm. In addition, the unit features a five angle valve job, as
well as high temp 17-7 ph springs (more durable and can withstand higher
temperatures before changing rate). Lastly, the PW46 is set up for a 1
3/4" pipe on the discharge side, and a 1 7/8" pipe on the inlet.
For Pricing and Availability, Give us a call at 321-722-1563
Holly Hartline
Hartline Performance
Wow, that is a great price on a quality gate!
