Aug 23, 2011 #1 F Fast4Ward Well-Known Member Joined Mar 27, 2005 Messages 1,162 the pump mounting plate has these honking rubber vibration dampners....is it not important to use them?. vibration kills....no
Aug 23, 2011 #2 R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Messages 13,391 There is nothing in the pump that would be vibration sensitive. It's more of a so the pump doesnt transfer vibration to what it's mounted too. If you decided you want to use them, you must use all 4 and bolt the pump to a bracket/plate/frame.
