Putting a switch to get fuel to all 6 cylinder
riviera
Has anyone ever heard of disconnect a wire to stop your car from spraying fuel in sequence and making it spray all 6 cylinder at one time for racing purpose only. if so what wire is it and is the a real advantage
That is called going from "Sequential" to "Port" fuel injection…but I dunno how to do it…
Claude
If you loose sync, you can go from sequential fuel injection to simultaneous injection which fires all 6 fuel injectors at the same 6 times per engine revolution. This could other problems, like backfiring though.
If I remember correctly; its been years...... it is the temp sender for the ECM. The car normally uses batch fire when cold then goes to sequential when warmed. Disconnecting the ECM temp the car thinks it is cold and gives batch fire. This is with the stock chip if you have a modern chip it may not work that way.
Rather crude way to gain performance and probably run way too rich.
I think you are talking about unplugging the cam sensor after starting which will put it in batch fire mode.
yes, the cam sensor.
the chip can be programmed to run in batch if you want.
but, there is no advantage. (there was some folklore years ago, but it is not true)
Bob
As Bob stated this does absolutely nothing useful under load. Even if the sequential was out of sequence it wouldn't matter at high engine speed unless certain cylinders were programmed to run with extra pulse width. There's not enough time for it to matter.
