quaife lsd 0-60
fast NY Six
After the limited slip install, the best 0-60 I could pull off is 6.4 sec. It was around 20 degrees outside. First gear is so tall, it's hard to launch without melting the clutch. The f40 transmission is very compact, the install wasn't too bad. This is my only experience with a fwd limited slip, I can say that it does spin a lot less easier than before. I can almost dead hook second gear, which was impossible before. I wanted to use a wavetrac but they are discontinued, so I went with quaife.
