I found these: Is this what you are talking about:
COMP Cams 941-16 - COMP Cams Valve Springs
Valve Springs, Single, 1.260 in. Outside Diameter, 447 lbs./in. Rate, 1.130 in. Coil Bind Height, Set of 16
Brand COMP Cams
Manufacturer's Part Number 941-16
Part Type Valve Springs
Product Line COMP Cams Valve Springs
Summit Racing Part Number CCA-941-16
Number of Springs Per Valve Single
Outside Diameter of Outer Spring (in) 1.255 in.
Coil Bind Height (in) 1.130 in.
Damper Spring Included Yes
Spring Rate (lbs/in) 441 lbs./in.
Inside Diameter of Outer Spring (in) 0.871 in.
Valve Spring Style Standard
Coated No
Quantity Sold as a set of 16.
Also are there specific shims that go with specific valve springs or what do you suggest for shims. don't worry I'm not installing this, but this time I'll need to watch.
