Oct 1, 2002 #1 O Otto J Well-Known Member Joined May 31, 2001 Messages 10,546 i was reading that the injectors should be fed by a relay from the battery, what is the best way to do this? cut into the factory injector plug and just use the original feed as a turn on? thanks Otto
Oct 4, 2002 #2 D DFIfixah New Member Joined Aug 23, 2002 Messages 23 Dont think you should have to use a relay for the injectors, the ECU should drive them just fine...
Oct 5, 2002 #3 B bobc455 Member Joined Jun 4, 2001 Messages 860 DFIfixah, I'm pretty sure the ECU only runs the ground, and the 12V+ for the injectors is fed by a relay that is switched with the ignition. (Otto, sorry I'm not familiar enough with your car to tell you which wire to take the 12V+ from, maybe someone else will chime in here) -Bob Cunningham bobc@gnttype.org
