turbojimmy
Supporting Member
- May 26, 2001
This is going to be a long one, but I’d appreciate any advice people with 4-post lifts can offer.
I think I’m going to pull the trigger on a Rotary 4-post lift. They’re probably the most expensive but also appear to be the best built. The purpose is mostly for parking, but I also want to make sure that it will help in ‘day to day’ maintenance of the GN (or other cars).
Obviously with the 4-post lift you don’t have the benefit of being able to raise the car in a manner that hangs the tires. But, with a jack plate you can at least get the car up to a comfortable height and jack up the wheels from there.
How about exhaust work, transmission work or other types of underneath-the-car work? Do the platforms get in the way so much that it’s not really worth messing with a 4-post lift from a maintenance perspective? I’m particularly interested in transmission work.
I have the ceiling height to put the GN on top and the Caddy on the bottom so from a parking perspective it’s good. If I get a car that’s much taller than the Caddy it’s going to be a problem but for now it’s good.
My second line of questioning is around floor prep. I have a fairly new house so the floor should be 3,000 PSI or better. The Rotary sales guy says that’s all I have to worry about, except for slope. If the floor slopes more than 1/8” over a foot then the lift needs bolted down. I planned on bolting it down anyway. My problem is that I’m pretty sure that the fill under my floor has settled and that the floor is essentially floating. I’d swear that when my wife pulls in I can feel it ‘bounce’ and when I drag the floor jack over it it sounds hollow. Might be my imagination though. The Rotary rep didn’t seem concerned with this as long as the floor was 3,000 PSI or better. The floor was installed with rebar drilled into the foundation walls as well as a reinforcement mesh. There is a pillar in the middle of the garage and there are cracks that start at the pillar and go outward making me think that the floor has settled around the pillar. But….looking at the edges of the floor where it meets the foundation there is no obvious sign that the floor has sunk. I’d be able to see a line where the floor originally was versus where it is now. It looks okay. I guess the question is did anyone have to do anything special to their floors? Given my description would you do something different in my situation? I’m concerned because the lift weighs 2,000 lbs. and the Caddy weighs 3,500 lbs. so that’s another 5,500 lbs on the floor that wasn’t there before. Again, the Rotary guy said that if the concrete is good that shouldn’t be a concern.
Last, for those that installed them yourselves how did you take delivery? They said I can have a flatbed (tow truck) pick it up and dump it in my garage. I could then disassemble the 2,000 lb. pallet and move the individual pieces. Thinking about it, a flat bed would only be able to dump half of it into the garage. I was thinking I could put 3” PVC under it in a few places and roll it into the garage.
Thanks,
Jim
Thanks,
Jim
