Hey guys,
I am in the process at this time of installing a new OEM pump motor for the "lovely" power master cylinder. The instructions that come with the new motor for bleeding are as follows.....
1. Fill the reservoir
2. remove brake line connectors from master cylinder. This i understand. This is located on the actual unit.
3. This part is confusing. It says have someone in the car press brake with no power assist and then tighten forward brake line connector. Then it says that you are suppose to release pedal slowly. After 5 seconds, reapply brake pedal and hold. OPEN FORWARD CONNECTOR 1/2 TURN TO PURGE AIR FROM CONNECTOR. TIGHTEN CONNECTOR. WHERE IS THIS FORWARD AND REAR BRAKE LINE CONNECTOR. IS IT LOCATED ON THE POWER MASTER UNIT.DO I NEED TO TAKE TIRES OFF THE CAR OR NOT??
pLEASE LET ME KNOW. NEED HELP.
THANKS GUYS
MICHAEL![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
THANKS GUYS
MICHAEL
