i am doing an engine build up with these parts:
gn1 heads(lightly cleaned up ports)
stock turbo trans am pistons(unless i sell them, then j/e or trw)
84/85 shim head gaskets(to compensate for tta pistons)
studs and billet main caps
204/214 sp cam
td 1.65 roller rockers
lightly cleaned up stock intake
jj 62/65 t body and matche plenum
race jace power plate
pte stealth turbo
mj 19 row intercooler(also have cas v4 i can use)
th dp and cutout
hot wired 340(may build up my own double pumper)
9" 3400 converter
built trans
my questions are :
what size injecters 55,65 or 72?(i have 009's and a 7th)
chip combo? (extender/translater?
my goal is 500hp and 600ftlbs tq, (with less than 20 psi boost) is this a realistic goal?
i am hoping i should have enough to go high tens if i coose to (on slicks)
204/214 sp cam
pte stealth turbo
th dp and cutout
9" 3400 converter
built trans
my questions are :
