Re: Freeze 12
Originally posted by Snappy6
STOP !!! Do not use Freeze 12 in any of your vehicles . One of the main parts of Freeze 12 is PROPANE. For those of you that live in Az, CA, it is aginst the law to sell or install it in your vehicle.
If you have a leak in your evaporator inside the vehicle and you smoke you could be putting yourself and your GN at risk. Anything electrical could trigger it ........
Don't know about the rest of your post, but no where in Arizona have I seen or heard it is illegal to sell or use Freeze12.???. If you can provide me with this information, I would appreciate it.
As far as 134a conversions "working fine", it may in most other areas of the country. When you have used it for a long, hot summer of 4-5 months of continuous 100+ degree temps, then
see how well it works, and what parts give out with the higher head pressures? Pusher fans and larger condensers are not an viable option on a Regal.
Like lots of subjects on this, and other boards, there are many different conditions that apply to solutions, some better than others. Depends lots on what is the final goal. In this case, location has much to do with "best" solutions.
I don't know about Ford dealers there, but here, no dealers or major shops do A/C conversions, simple reason, they are a big problem and do not work as good as the original system.
