race built 2004r trans wit brake and converter $2800
TurboTA3.8
You wont keep up the pace
2004R TRANSMISSION
* HARDENED PUMP STATOR * 10 VANE HI VOLUME PUMP KIT PTS SUPER PUMP ALL GM PARTS * CHROME-MOLY PUMP RINGS * .570 TV BOOST VALVE * .400 INT BOOST VALVE PTS * BILLET SERVO * RAYBESTOS "BLUE PLATE" DIRECT CLUTCHES * ALTO 2 3/8 inch H/D BAND * 300m BAND ANCHOR * ROLLER BEARING CENTER SUPPORT * TEFLON C/S RINGS * PTS "BAT BRAKE" Transbrake * BILLET INPUT SHAFT * BILLET CHROME MOLY OD PLANETARY,* BILLET INTERMEDIATE FORWARD CLUTCH DRUM SHAFT * TEFLON PUMP & DIRECT DRUM BUSHING * PTS "BOTTOM FEEDER" FILTER/SUMP SYSTEM * RAYBESTOS "HIGH STATIC" LOW REVERSE CLUTCHES * PAN DRAIN PLUG * NEW TCC SOLENOID (If lock up) * VALVE BODY & GOVERNOR MODIFICATIONS * HARDENED H/D DRIVE SHELL * ROLLER BEARING L/R CENTER SUPPORT * ROLLER BEARING PARK GEAR SUPPORT * ALUMINUM PAN * PRO TORQUE 3800 STALL CONVERTER RATED FOR 1000HP, TRANS IS FRESH ONLY 3 LOW 10 SEC PASSES ON IT WORKS FLAWLESSLY 1.39 60 FOOT
$2800.00 OBO
FREE INSTALLATION AVAILABLE FOR LOCAL SALE
200 4R
IM INTERESTED. I LIVE IN SOUTHERN CT. U SAY THE CONVERTER IS RATED FOR 1000 HP BUT WHAT IS THE TRANNY RATED AT?
THANX.
well eric at dynotech is making over 700 to the wheels threw his and thats 900 to the flywheel so id say atleast 900
george
Is the pro-torque a lock-up or non lock-up and would you consider selling it seperately?
200 4R
ILL TAKE IT GEORGE, THE WHOLE PACKAGE. CALL ME (203) 650-2026. I SENT U AN E-MAIL TOO.
Re: 200 4R
sorry man some one beat you out by 2 mins if he backs out ill let you know right know a sale is pending
george
200 4R
GEORGE I TOOK TOMORROW OFF FROM WORK TO COME DOWN TO PICK UP THE TRANNY. CALL ME AT (203) 650-2026 SO I CAN GET DIRECTIONS. I TRIED CALLING THE NUMBER U LEFT BUT GOT AN ANSWERING MACHINE. THANX.
BRETT
CLARIFICATION
I BACKED OUT FOR MONEY ISSUES. I DID NOT HAVE A PROBLEM WITH THE SELLER OR HIS TRANNY.
JUST WANTED TO MAKE THAT CLEAR. IT'S A KICK ASS TRANNY AND CONVERTER.....! WILL COST AROUND 5 G'S NEW.
if anyone needs to know about his unit it has the best of everything call eric at dynotech he just went threw the unit and also made some more upgrades this is the best 2004r money can buy
george
Originally posted by TT/Ameasap
Why is everybody backing out? I am interested...But just wondering.
Bo
well if your interested tell me what you want to know
