I'm looking to have the supply line track the return line on the top of the intake on the driver's side, w/both lines exiting rear driver's side and then route down near the frame. At this spot I think I have access to all the hose clamps, cam sensor bolt, etc. Anything else I should be worried about? Only alternative as I see it is to route the line closer to where the stock setup went and go down behind the alt/ac bracket setup, which would still have it in that direction. Any countervailing thoughts?
