racetronix hot wire instal?
hang10
old surfboards wanted!!!
Where does the 6" wire with the clip on the end-coming off the spiked ring terminal-on the relay side of the harness go?? I looked on Racetronix web site ,but i did not help.Thanks in advance-Kurt:confused:
What Trent said. Ground cable, connect to the lip of the tank.
Dannyo
Make sure you scrape off any undercoating to get a good ground. Otherwise your hotwire will be useless
