Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
A pulse dampener makes sense.
SignUp Now!Sure does. I remember looking for one, but never seen one for automotive use.
I think the issue of the fuel pressure jumping around could be related to how big the injectors are.....
This would be due to the amount of fuel being injected at various rpms....in the import world they have a damper atteched to the fuel rail to help ease the pulsating effect on the regulator...
Try this I'll bet when you put the car into batch fire mode the fuel pressure moves a lot more vs Sfi.
There could be other factors at work to. Like how smooth of flow is the fuel up to the rail and thru the rail. If there is any turbulence in the fuel along the way that energy is being shown in the fuel pressures moving around. The best way to test this is use the same test car for different regulator so the testing is done in the same repeatable manner .
I might set up a complete fuel system and do some testing I'll just have to create a way to drive injectors...
