Remove 3-4 grams from the primary governor weight with a grinder. You need an accurate scale to do this. You may want to try removing 1.5-2 grams and testing it. There are several things that can effect the shift points a little besides the governor. Usually 1 gram is 200-300 rpm.
If your TV cable is adjust right, at or close to max. it won't affect you WOT shift points. But tightening it will affect the PT shift points & firmness.
This is correct. The TV cable should be at max at WOT so it wont have any effect on the WOT shift point. The way i described is the way i always do it. You could clip a few coils of the spring but you wont get much out of that and it may delay part throttle upshifts a little more and make the spring more prone to fly out of the governor if not retained.
If you want it to shift at nearly the same rpm you need to modify or replace the 2-3 shift valve spring. You can raise or lower both by altering the governor.
