CamoDeafie
- Jan 7, 2010
you can measure the decal's size and see if you can get the T-type center cap decals off ebay or here; and see what happens?
SignUp Now!you can measure the decal's size and see if you can get the T-type center cap decals off ebay or here; and see what happens?
Anyone know the voltages of the 2 wires? I know the 4 wire connector goes to the distributor and the big wire is to the knock sensor, but the 2 wires that hook up to the harness is what I`m trying to figure out.
No one knows?
It must be a BOP then... it was a valley
Almost back together.
If it is the original tranny then it should be BOP only but if it's been changed then it may be a dual unit. Can't tell from the pics because I need to see the tranny mouning to the block.
Thanks Charlie. Anyone know any part numbers for flat top pistons? I have been thinking about sticking with the N/A setup with 12.1 compression, get a bigger carb, KB intake, bigger cam, better headers, 2004R, rear gears?(373 in it now)... just thinking of my options.
