3.8 " is the stock bore size. lots of MFG for pistons out there, what ever you can afford.Ok, I like the alloy piston idea... the lighter, the better. Summit has me confused with this mm bore... which is stock?
3.800 in. - 3.8L/231 - 1979 - REGAL - BUICK - SummitRacing.com
Another random one... has anyone ever used or seen a Vortech supercharger on a Buick 3.8/4.1? I seen it on a '98-02 Regal, one of the guys in my car club has one... I thought it was just a normal GS, but it sound louder and way more bad ass than a GS:biggrin: A lot of V6 Mustang guys are using them and I thought about it too, with a B/T carb and Weiand intake... but the SCer is more cash than I ever want to pay... just a thought.
I bought some petroleum jelly last night and was just about to try that. If that don`t work, I was going to drain the oil and poor it down the valve covers and then try to prim it. I hope I haven`t burned the bearings already![]()
Jase, Take the oil pump cover back off and jam the pump cavity and gears with petroleum jelly or grease and then re-install the pump cover and then run the pump with a drill to prime it, the pump should pickup oil and bog almost instantly after that.
Well, its running... like shytI think the intake gaskets is leaking... I power washed the motor down and around the intake(and the ground
) there is still oil leaking. When I hit the gas, it smokes like a mofo and sputters. I broke a bolt off in the passenger exhaust manifold so now that leaks, the exhaust gasket on the drivers side is leaking... I`m going insane
Um...No! Chevy parts won't fit on a Buick.
Can I run E85 with a stock carb and all? I know I would have to replace the paper and possibly the plastic fuel filters too?
Does anyone know if a Buick series 1, 2 or 3 supercharger will fit a Firebird/Camaro 3800?
Here's a semi-serious question for you guys: how the heck do you change plugs on these carbed turbo cars?
I bought an 83 T-type yesterday. Motor condition unknown; the car's been sitting a while. I will probably turn it over, put some oil down the cylinders, and see if it will run..
I have to say though, looking at that rat's nest of exhaust plumbing, hoses, and vacuum lines is enough to make me tempted to yank the whole thing out.![]()
